No idle?
59 BUS - May 28th, 2003 at 10:46 AM
Any common causes for a carb to not want to idle? It's a 30 pict.
Bizarre - May 28th, 2003 at 10:53 AM
Ooops - posted this on the other question
I am stealing Aussiebug's thunder (sorry Rob) but have a good read here and see if it helps
http://www.geocities.com/aussiebug1970/30PICT2.html
aussiebug - May 28th, 2003 at 04:44 PM
Don't feel sorry for "stealing my thunder" Blue - I'm happy to have my articles posted if it helps another VW owner.
59 BUS - May 29th, 2003 at 09:31 PM
Well i've just spent the afternoon rebuilding my carby. And it still wont idle!
I have pressure tested the manifold, set the timing (static 0°) and set the idle to high. It seems to have a slight miss every now and then, above 2000 rpm.
As soon as you take your foot off the gas, it dies like turning the key off.
Any ideas?
Bizarre - May 29th, 2003 at 10:06 PM
sorry - why 0 degrees (how did you do the degrees symbol?)
what motor is it ? a 1641 yes?
and a 009?
why not 7.5 ?
What about spark?
leads?
cap and rotor?
Has this only happened since you took the duals off?
did this carb ever work?
59 BUS - May 29th, 2003 at 11:15 PM
I normally set it to 0° as a starting point and tweek from there, also I know that it runs at that setting.
I get a good spark, from what I can see through the clear dizzy cap, and runs well and smooth at high revs, apart from a very slight miss which I can hear every now and then.
This carb is what was on before I tried the duel carb set up and worked fine.
To get the ° symbol hold down the Alt key any enter 0176 on your keypad, this method gives you access to the extended ASCII keyset, just try it with different numbers. ±²³´µ¶·¸:thumb
70AutoStik - May 29th, 2003 at 11:45 PM
Athough you've rebuilt your carb, it's possible a passage is still blocked. The best way to check this if you have the gear is to visit your local wrecker and pick up an EGO sensor, then tap your exhaust and fit it. I'm not sure if Dick Smith still sell them, but Jaycar and Altronics still have a kit to read the mixture reading from this; if not, many auto stores now sell a ready-made unit to do it.
Another thing to consider is your clear dizzy cap - they are notorious for leakage. Just fit an old stock one to prove this isn't the fault. A leaky dizzy cap usually causes problems at low to mid revs, but it can be anywhere really.
fish - May 30th, 2003 at 05:17 AM
aha!! so after abusing the carby all this time i find i have a crack in my dizzy cap. Bugger bugger bugger:bounce:bounce
aussiebug - May 31st, 2003 at 10:10 AM
It doesn't even need to be cracked - the clear caps seem to have a problem with cross firing - maybe the plastic they use?
70AutoStik - June 1st, 2003 at 04:04 PM
Yes, it's the plastic they use, it forms invisible carbon tracks rather quickly. The good-old bakelite caps from Bosch may not look as pretty, but they work a lot better, a lot longer.
59 BUS - June 2nd, 2003 at 10:38 AM
I tried another Carb, that didn't work at all. so I rebuilt my 30 pict (fully). Set the timing (+30° max at 3500rpm) yes a 009.
Set idle at 850rpm, idle air screw at 2.25 turns out. cleaned clear 009 Cap. Now I have an idle BUT every now and then it will almost stall then idle up again? Maybe I'll change the condenser?
70AutoStik - June 2nd, 2003 at 10:21 PM
First, borrow a stock Dizzy cap - cleaning won't fix it. The condensor usually won't allow the engine to start (or produces misfiring at higher revs first,) but it's worth looking at down the track.
