Took the handle off with it in the car and now i can't get the reverse cable that goes through the middle to slot back in...whats the trick???? or do you need to unbolt from the chassis???
unbolt it to assy
Whats the way to align the gear shift once removed? stick it in second gear then re-tighten the bolts?
Whats at the bum end of the berg shifter? How is the cable hooked up to the reverse shift?
i think theres a cabel  with a crip on the end of it
yes adjust while in 2nd gear  and centralise it b4 tightening
