lhd master cylinder
grogy - September 2nd, 2008 at 02:24 PM
anyone put one in a rhd bug, lhd fittings connect to side closest to tunnel , not much room. if u turn it upside down the connections to the resivoir are underside, under pressure to leak. can the lines which go to the back of the car be fitted to the front of the cylinder [close to frontof car] and the 2 front brake lines be moved to the rear position. can the electrical fitting be moved to any spot. appreciate your help...... grogy
toplessbug - September 3rd, 2008 at 12:06 AM
just get a rhd one ,the lines are all arse about face --------they are bloody brakes you are stuffing around with ..........use the guts of the lhd one to rebuild your old one and you will have a spare
