i have just acquired some new brms that came with 135s on the 4.5 front wheels
i am putting them on my lowered daily 65 Squareback (lowered 2 inner splines at the front little bit of rubbing with stock tires) and have heard that
they are a bit scary to drive on...?
i am wondering whether i should sell them and buy something like a 165/50 or 55 for a bit more handling?
what do you suggest?
thanks
Keep them, depending on your driving style and local roads, 125's and 135's can be a little scary at times with high speeds and grooves etc in
roads.
I've run them for years, but you do sacrifice some handling for a little more style.
My 2 cents.
yeah i thought so much about the handling - a bit of give and take
i was also thinking about the low profile 165s for clearance issues - have read some threads on the samba where people say its more about the profile
than the width (165/50 is a shorter tire than the 135 nankangs)
is this true? do you think it would increase/decrease rubbing if they were a bit wider but shorter? i suppose it depends on wheel offset...my fronts
have ET23 offset
Who makes the 165/55 or 60's. Am having the same problem on the front of my splitty. Thanks Aaron
Anyone know what brand they are?????? Aaron
Federal makes FD1 165/50 and 165/45 not sure about the the the 55/60s.
Bridgestone also make a 165/50's (RE40 tread)
Cheers for that.
