What rims fit 82 transporter
satori - November 2nd, 2008 at 07:08 AM
Hi everyone. What rims can you put on a 82 transporter. Will late 90's model wheels fit or any other brand cars mags?
thanks
hellbugged - November 2nd, 2008 at 08:17 AM
mercedes.......... steelies or mags
Bizarre - November 2nd, 2008 at 09:19 AM
most kombi wheels 5 blt 112 PCD
T4 are different
At present i run 17" x 7" with a 23ET
http://i35.photobucket.com/albums/d170/blue74l/Daisy/101_0772.jpg
I use to run 15" x 6" 36ET
http://i35.photobucket.com/albums/d170/blue74l/Daisy/101_0762-1.jpg
Bizarre - November 2nd, 2008 at 02:57 PM
here is my 82 with the cookies
http://i35.photobucket.com/albums/d170/blue74l/Daisy/Jan2752.jpg
greedy53 - November 2nd, 2008 at 06:10 PM
the mombi are 112 pcd with a 35 mm offset so start there and use bthis
http://www.carlsalter.com/wheel_fitments.html
pod - November 2nd, 2008 at 06:29 PM
these are the merc wheels i had on my 82
http://img.photobucket.com/albums/v225/mrvw061/vw%20stuff/113-1338_IMG.jpg
vwtyp2 - November 3rd, 2008 at 08:33 AM
I had Passat 17"s on mine.
just need to machine the centre bore a little.
It had Audi rims on it when I got it.
DirkHedde - November 4th, 2008 at 01:28 PM
I have been told in the past that T4 wheels will fit as they have the same bolt pattern if you like the commercial look. i believe that many alloys now seen on kombis do not meet the load rating required for this type of car. same goes for tyre choice. i dont believe they make a low profile 17 inch light truck tyre? but i may be wrong.
Andy - November 4th, 2008 at 10:27 PM
I have Merc ET39's for my Bay kombi. These did NOT fit on a '89 T3 kombi.
Bizarre - November 6th, 2008 at 09:02 PM
Why not??
What fouled??
Am surprised
Andy - November 6th, 2008 at 09:54 PM
On the front the rim + tyre hits the top of the suspension, so physically will not bolt on.
I have seen steel merc rims on T3s' though, just not sure what offset they were.
Stock T2 and T3 kombi rims are the same offset I think, and ET39's are close to stock offset. (sorry I don't have figures, but can measure if you like).
Steering and handling are better if you can stay close to stock.
kombi kountry - November 11th, 2008 at 01:36 PM
quite often need to fit spacers when fitting other manufacturers/models (audi, merc, other vw) wheels on T3's due to issue mentioned above.
there is an endless supply of info on brickyard and samba regarding after market wheels for T3's
