How to remove a door hinge pin???
68AutoBug - June 8th, 2003 at 01:20 AM
Can anyone tell Me if there is a trick to removing a door hinge pin on My 68AutoBug... or do You just need a LARGE Hammer?? and a can of WD 40....
It seems they were put in with a very large hammer!!! Do they only go UP??
vw54 - June 8th, 2003 at 09:02 AM
Lee Remove the door from the car first and turn it upside down, support the hinge before hitting it or you will rip the hinge from the door.
Dasdubber - June 8th, 2003 at 09:21 PM
I had to heat the hinge up with an oxy (had to repaint anyway) then use an air chisel with a pointed bit to drive it out. A big hammer and punch didn't shift it at all.
Hope yours are less stubborn than mine!
