i was wondering if anyone knows what is going on with my car . battery isnt charging but when i push the left side leaver on the regulator down it
starts charging and the genny light goes out but when i take my finger off it comes up and stops charging and the genny light comes back on. i have
changed the regulator twice and swapped the wires over on the genny but still nothing. any help would be greatly appreciated cause i am sick of always
charging batterys every 3 days
THE MOVEMENT OF THE TERMINAL EFFECTS THE POINTS GAP INSIDE THE REGULATOR
you need to remove the cover and ADJUST the points gap to allow the points to close at when the engine is reved
Take it to your local Auto Electrician and get him / her to adjust for you
Maybe not enough Voltage to pull the points closed...??
Generator may need over hauling..
You need to check how many volts at the Generator..
should there be sparks coming off the brushes when its charging
