i have a linkpin front end dropped spindles and adjusters. i would like to know what size sway bar for performance application, and adjustable or
fixed.
i was told 18mm adjustable would be overkill.
the rest of the car will be set up as well and running 6j and 7j fuch's.
any input would be great.
same sizes i run right thru there...........i still also run the standard front bar as well............love it!,
totally transformed the car, get a rear one as well!
don't be afraid to reset the front ride height a couple of times to get the "rake" balance and handling dialed in to your likeing
what size is the standard front bar??
12mm I think.
You have PM regarding spring plates.
Brendan
