Can I run a Compu-fire electronic ignition replacement module in a 009 in my 6V type 3?
no
u need 12volts
bloody compufire i have had 2 and both failed in the first month 1 i imported from america no refund too hard and the net i won in a raffel again bloody compufire
Greedy53, that sounds pretty poor man, gives me second thoughts on it.... but looks like i wont be getting it anyway.
cheers for the replies guys.
does anybody know if anyone makes a 6v module??
yer really poor and my mate his failed in the second month and another mate who had 1 sent with mine failed in 3 months and there not blody cheap
Just found out on the Samba that Petronix does a 6V system. will let u guys know how i go..
Steve were they definately compufire kits?
compufire is noramally pretty good and have a decent warranty to
theres kits like the accufire empi crap that looks indentical to compufire but have a spectacular fail rate
izac,
Here's a pertronix from cip1
http://www2.cip1.com/ProductDetails.asp?ProductCode=PER-1847-AN6
I'm sure there are others who sell them, especially in the states.
I've heard that the 6 volt ones don't cope very well with the drop in voltage to the coil caused by current draw from the starter motor. I reckon a
"hard start" relay would sort that out. A lot of 6 volters have had one installed already.
Regards,
Matt
Thanks Matt that looks like what i want.
could you explain about the Hard start relay a bit more... what exactly is it?
yep they were compu crap still have them in the shed so i can yell at them every now and then
izac,
Here is some info and a wiring diagram for hard start relay:
http://www.oldvolkshome.com/hardstart.pdf
I have been reading up and it seems the voltage drop affecting 6v electronic modules does not only happen during starting.
You have to have all your electrics in good condition or the engine can start to misfire or even cut out if voltage to coil drops. Good earths, clean
contacts, good ignition switch etc.
One fix I came across, (was for beetle but probably the same for type III) is that the main power lead from battery doesn't go directly to the
ignition circuit. It goes to the headlight switch then a jumper wire goes to ignition. People have had success with reversing these wires, but I would
imagine you would need your head light circuit up to scratch if you did this, to avoid dim lights. (or should that be, dimmer lights?)
Regards,
Matt.
thanks for that Matt. I will give it a read.
Yeah it sounds like a fair bit of trouble... maybe its not worth it for a daily driver not sure i want dimmer lights as they already pretty much as
good as candles
... but it would be handy.
Why not convert to 12volt????
yeah ok man you can come over and do it for me...
ive had a compufire in my engine for longer than ive had my engine, previous owner put it in, and its been hastle free.
But yes it does come down to using the right coil
i will never go back to points again, the bug and van both have electronic, even my 323 daily runabout has it. points are the worst most anoying bit
on any old car IMO
