Hi All,
I picked up my baja last week and I'm having a ball, however, I pulled the engine cover off today and there is no air filter at all. This is my first
vw so I'm not sure what is supposed to be there, or where to get a replacement. Basically there is a rectangular base plate with 2 large holes for
the two throats of the carby and some small ones presumably to bolt the missing bits to. I realise I should have tried to find something to identify
the carby, or taken some pics but it got dark, I will get pics and post them if no-one can help me with the info I've given.
Any help is much appreciated, Thanks.
Dan
try your local auto parts store for a new air filter set up,just get the name off the carby ,and maybe some part no.s so as to get the right sizing
There are about four different options, from the most common, Weber DCN or DCNF, Weber IDF, Weber DGAV(?)progressive, Dellorto DRLA, Zenith NDIX. Most of these, all except the Zenith, take one of two different types of air filter, both of which should be available from Rod Penrose, he's a vee dub guy and an agent for Unifilter. Best look on the carb and advise how tall an element will fit in the space you have, go for as big as you can, they should be available in 2", 3" 4"..up to maybe 6", then if you go in the dirt or beach alot, you should go for a gauze element and an oiled foam outer band, even an outerwear over this is the ultimate setup.
Thanks guys, I'll head back to the shed tonight and see what I can find out.
