can someone tell me what wires go where on the engine??
just need to know where everything electrical goes except for ignition leads but especially off the coil
Luke
Black wire from ign switch to coil +, also on this terminal you possibly have wires to choke element and/or idle solenoid. Coil - has a usually green wire goig to points and condensor on distributer. Thin light blue wire to oil press sender. Gen/Alt wires depend on what charging system and model.
the engine is from a 71 1600tp
Green wire DF
Thick Red wire and the black 1 to D+
its a 71, its not gonna have the black wire for the diagnosis circuit
