Fellow rev heads,
I'm after a little advice with which NOS system ? I'm currently using a 500 Turbo Prepped Holley 2 Barrel Carby with a Garret T3/T4 Hybrid Turbo
(draw through system) , but I can't decide where to inject the NOS ? (50-75 shot)
Should I use a Holley injection plate?
Or
Straight into the manifold ends into the heads ?
Any one had previous experiences with this ? Good and Bad Points ?
Any advice is appreciated.
Who is out of control
Where a bad influence on each other
I'm still a little troppo from
living in Darwin too long
Don't all rush to give me advice
Whats the purpose of the NOS VW Freak? If you're using it as an intercooler in a bottle and to spool quicker then the best place for it is pre-turbo
in the carb manifold, which is cool cos it means you only need a single injector system. I have an NX kit with a twisted sanity controller that I am
yet to fit to my 54 to do just that - intention is to improve 60ft times by reducing the spool up and improve overall power by reducing the temp of
the charge - NOS out of the nozzle is at a ridiculously low temperature. I don't intend running lots of NOS on boost though, I'm planning to set it
up so that the NOS cuts out when bost reaches a set level (to be determined by test & tune).
I haven't experience of a full on system for on boost applications though as I've not looked into that at all.
You should have a lot of fun with that!
If its for cooling use water/meth set up instead !
water/meth isn't injected at -129 deg F bug_racer!
