Evening all,
My 1970ish beetles brakes are gone - completely, no brake fluid left and no indication as to where it's gone. I've got a preferred workshop out
near my work Boronia way, but I live Greensborough/Eltham and was wondering if anyone can recommend anywhere I can go to get it fixed locally. Looking
for quality, not cheap (not too expensive, mind), so if there's some recommendations, be happy to hear them.
I would say the brake master cylinder leaking through the secondary cup into the centre tunnel. Replace the master cylinder and i think you will fix the problem.
try volkshome automotive thomastown.
You could also try Volkscourt (WM Motors) also in Thomastown. Ivanhoe Court (Not sure of the number). I got a master cylinder there recently for the
same reason.
Good luck.
Lee, the kits aren't expensive but 99 times out of 100 the cylinder is pitted badly and needs resleeving or replacing,most times we opt for the latter due to cost and time factors in resleeving.
VolkWerke is in Greensborough
Factory 1, 171 Para Road Greensborough 3088, Melbourne VIC.
Email & Phone:
enquiries@volkwerke.com.au
Ph: (03) 9435 1868
Thanks all. Got Erik (err, the Beetle) back today from Volkscourt - blown rear left brake cylinder. All good now, can now go places and stop when I get there.
Great news Eplatypus. A lot cheaper than a master cylinder!!
