Leaking pushrod tubes on a 36hp
matara - September 15th, 2009 at 02:38 PM
Is there a way to stop a leaking pushrod tube on a 36hp engine without pulling the engine out and taking the heads off?
vw54 - September 15th, 2009 at 04:31 PM
nope has to be replaced with new one and seals engine out heads OFF
bajachris88 - September 15th, 2009 at 05:08 PM
IF you got the tools (torque wrench and sockets)
You could have it organised in a whole morning easily. The seals cost next to nothing either.
vw54 - September 15th, 2009 at 05:15 PM
dont forget the seals and tubes are completely different to later engines not same size
68AutoBug - September 16th, 2009 at 12:53 AM
You can take the old pushrod tubes off...
and replace them with the adjustable type
using new silicone pushrod tubes.
I always cover both sides of the seals with Permatex non hardening gasket cement, I hope this helps..
Ring Mick Motors etc and ask if they are any tricks to doing the job..
vw54 - September 16th, 2009 at 06:54 AM
no you carnt as there a different size not available in the split adjustable tubes
dangerous - September 16th, 2009 at 07:42 PM
Yes much smaller seal.
Youn could always make some.
There are various aluminium tubes that slide within each other.
You can machine a step on each end for the seals,
and flare the larger tube to accept another seal in the middle.
a circlip and a spring to keep the tension on the seals.
Just like the pauter ones in this link:
http://forums.aussieveedubbers.com/viewtopic.php?tid=47383&page=2
grumble - September 16th, 2009 at 08:32 PM
You will need to remove the cylinder heads as the seals go as hard as a rock over time.If you need the seals or a gasket set I have both.Cheers Les
