Lowered rear shocks?
alien8 - October 7th, 2009 at 03:30 PM
So I know that when you lower the front you usually run with a lowered shock or strut insert but what about the rear?
Do the part places carry a shock for a lowered rear or is it the norm to just use the stock shocks?
If any one runs lowered rear shocks where did you get them , what brand and part no.?
Many thanks Brad.
VWCOOL - October 7th, 2009 at 03:37 PM
you can use normal ones (within OE suspension stroke limits) because the bump stop is separate
alien8 - October 7th, 2009 at 03:45 PM
I was just thinking about ride quality with rear gas shocks. You would think the ride would be softer with a shorter gas shock ?
VWCOOL - October 7th, 2009 at 03:48 PM
no, disrgarding bump stops, the ride height doesn't affect ride quality. Shock/spring rate does
Klaus - October 11th, 2009 at 05:31 PM
I run empi 9650 shocks from classic in my split front and rear , cheap as chips and do the job until i can sort some adj koni's.
