i wonder if anyone has answer to my dilemma
my indicators either don;t flash or blow the fuse
i have checked the individual globes and connections at the guards but these seem ok
for a while the passenger side worked front and back but the speed was variable
thought it may be the flasher - so replaced this
still no joy
any suggestions?
also a photo of the flasher unit wiring may help
heres a diagram
check that none of the wires are loose or touching earth
could be the switch grounding
thanks silver
the flashers i have seem to have only 3 plugs - more in the diagram
where would i look to find the indicator switch grounding?
