removing starter bush...help!
djnee - October 19th, 2009 at 08:49 AM
ve got the car on ramps...starter motor out....
How the hell do you remove the old bush? its so bloody tight under there which doesnt help i guess.
Managed to chip a bit of it out with a screwdriver, but cant see how you can get anything in there behind it to prise it out.
Swift help appreciated as im in the middle of the job!
thx
vw54 - October 19th, 2009 at 08:52 AM
GET A metal cutting tap dosent matter what thread it is thats a tight fit into the bush and cut it into the bush
then u can use pliers to remove the bush
matberry - October 19th, 2009 at 09:05 AM
As above or a strong bent tip screwdriver (bent to a shallow 90* hook) but the 1/2"(?) tap works much better.
djnee - October 19th, 2009 at 09:34 AM
fixed! thanks for info!
managed to whack a bolt into it and then pry out with clawhammer!
1303Steve - October 19th, 2009 at 10:43 AM
With the tap method if the motor is in the car still, just keep screrwing and it will bottom out and then get driven out by the tap.
