Long and short swing asxles
dbmanx5 - October 26th, 2009 at 09:57 AM
Hi,
I'm sure this has been discussed a few times. I have a 1500 transmission in a manx clone but tyres stick out past the body in the rear.
I have read somewhere that there are short and long swing axles. What are the difference in lengths? What years were the different axles on cars? Is it worth looking into cahnging them or change the wheel size at rear meaning i need to find new rims.
Any advantages or disadvatages for having either long or short axles?
vw54 - October 26th, 2009 at 10:34 AM
the short axles are from pre 67 beetles from memory there approx 25 to 30mm different
dangerous - October 26th, 2009 at 04:08 PM
Dave is correct.
The axle and tube are 29mm shorter,
plus the spine is 15mm shorter too,
so this 15mm will have to be machined off the drums' snout, to fit onto the early axles.
1303Steve - October 26th, 2009 at 05:17 PM
The actual tubes are all the same lenght, its the cast bit on the end that varies in lenght and the axle of course. They're actually made in two pieces and after a pin has been removed the tube and end casting can be pressed apart, cunning Germans.
