Ok guys, after a stint working os, and other distractions I'm back to finish the super charger install on the replica.
I have a 1916 with a 110cam (appRently), going to replace the rocker shafts with solid ones, question is though should I fit rockers with more lift on
a boosted engine?
hey Nick, glad to here your back at it
just be aware W series cams can only run 1.25s at the most so no 1.4s
but seeing as its a force fed engine anyway ratio rockers probably wont give as much bang fo buck as they would on an N/A motor
it will keep the valve open longer so more fuel in is good use the 1.4s
you may find that getting air to a motor that big will be a problem fuel is easy i have noted that with the smaller blower a 12 is a bit small but the
14 should do a better job
have a look at the amount of air that can be shoved through a pair of webbers or caddies big holes
just a thought
just a question on my personal interest...
how much lift (@valve) can a standard head sustain?
