basic ingtion wiring
trikeman - January 28th, 2010 at 12:46 PM
on my vw 1600 trike I accidentally pulled all the wires off the ing coil & have l
lost wiring diagram, could some one telll me
where the wires from the ingcoil should go to, which ones go on the postive sied & negative side, i would be msot grateful for seme help, it is 12 volt and has a seperate alternator,
thanks chris
jsheppard64 - January 28th, 2010 at 01:58 PM
found a diagram for a super might help
vw54 - January 28th, 2010 at 03:47 PM
the black one goes to the + side of coil and the green one goes to negative and dissy
if u have a mulit meter turn ignition on and determine if u have voltage on the black wire
