is a 1600 85mm bore?
vwsteve - May 5th, 2010 at 04:31 PM
ive packed my books and cant remember if a 1600 has 85mm bore?Can someone please let me know, cheers
also what size is 89-90mm bore?
Bizarre - May 5th, 2010 at 04:50 PM
85 - 1584 (1600)
87 - 1641
88 - 1679
90.5 - 1775
92 - 1835
94 - 1916
http://www.aircooled.net/gnrlsite/resource/specgeninfo/calcs.htm
vwsteve - May 5th, 2010 at 05:26 PM
thanks mate
1500S - May 5th, 2010 at 05:59 PM
1584 (1600) = 85.5 bore is it not??
DH
vwsteve - May 5th, 2010 at 06:35 PM
i only used an old crap measuring tape to get the avg measurement
Joel - May 5th, 2010 at 07:27 PM
Steve, where abouts are you measuring from?
if its the piston itself or the inside of the barrel your sweet, but the hole in the case/heads and outside of the barrels is gonna be bigger
vwsteve - May 6th, 2010 at 07:43 AM
yeh i measured the barrel diameter,cheers
funbug - May 6th, 2010 at 12:24 PM
Originally
posted by vwsteve
1584cc is a 85.5mm bore
matberry - May 6th, 2010 at 10:00 PM
Originally
posted by funbug
posted by vwsteve
x2....the rest above are accurate.
Although 90.5 is commonly stated as 1776.
It actually calculates out to 1775.35, so 1775 is technically closest, rounding up though is an automotive necessity, hey, the manufacturers do it in
a big way, so i like to go with 1776.
