74--1600TP dizzy/carby question
57 oval - May 23rd, 2010 at 08:48 AM
I have a 74 beetle with a 1640 TP and it has a slight flutter at idle along with a small flat spot when you hit the throttle. It is fitted with a
34pict3 carby and has a 009 type distributor. I believe that it should have a vac advance type dizzy. I read some were that this combination I have
will give me the problems I am having, I also read the carby mod to fix it, but what my question is does anyone know the correct model carby and the
correct model number dizzy that I should have. I am keen to have it idle and accelerate as it should do.
RJ
65standard - May 23rd, 2010 at 03:20 PM
Originally
posted by 57 oval
RJ
I have this information. Cant remember where I got it from, but I have it anyway.
34PICT-3 VW Dist. 043-905-205 or Bosch 0231 170 034
Hope this info is of help to you. I'm sure there'll be others to jump in and impart their knowledge also.
Cheers,
Norman
