Seat Belt Holes
clinker42 - June 8th, 2010 at 04:11 PM
Hi Guys
Where is the front lower lower seat belt hole, I forgot to cut the hole in the carpet and have now got everything installed.
If someone could draw and arrow on this pic it would be really appreciated.
waveman1500 - June 8th, 2010 at 04:37 PM
I'm pretty sure that it goes through the vinyl cover over the B pillar, not the carpet. The bolt hole is definitely on the B pillar, not the floor or the heater channel, so have a good feel around with a stick through the vinyl at the base of the pillar and you should be able to find it.
Joel - June 8th, 2010 at 04:39 PM
yup just under the headliner
