Hey guys im taking out my 40hp and puting in a 1500 TP any recommendations on what i should to prevent from having any probs and hassles.
The engine comes with everything except exhaust - how much are these from wrecker?
:beer
Costa
Has yours been convered to 12 volt??
Make sure the flywheel fits. You might need to grind out the bell housing.
Also make sure the starter motr / fly wheel are compatable
Yes mines been converted to 12v
what about fuel lines should i get those changed again?
That is a general maintenance thing
They should always be in top condition - not just when you do a motor swap
cool anthing else?
Engine mounts
You will need to look to see what sort you have but would well worth the $$ and time to put some poly engine mounts (the one under the g'box)
while the motor is out. Only an extra 10mins
If YOU havent done them - almost guarenteed they are split and your motor is only resting on them
Ok cool ill tell Steve to suss them out for me.
One more question b4 this i had a 40hp in it and it felt good- going to a TP 1500 how much more power will it have and will the car feel much more
faster?
(i know it depends on how the engine is tuned etc but what the min power i should expect?)
Your old 40hp probabally put out mid to high 20 ponies at the wheels.
I am guessing this will put out mid 30 ponies
On Dyno day a stock 1600 was getting 39. The new motor will be under that.
Pretty sure Lugnuts had a 1300 and that was 30 or something so a 1200 a bit less
Yes the difference should be noticeable. I am guessing a 25 or more % increase. You wont be beating the Audi but you should now be able to overtake
the old guy in the Volvo
Costa
i saw it parked on the footpath today.
Is that the waiting room??
Looking good
Ok cool so i should feel a difference.
thanx for the compliment, it got a lot of attention on norton st as well - not bad for a dirty beetle
I think its the colour with white its very eyecatching - that and red beetles
My stock 1500 SP was putting out 34 Hp at the rear wheels, and I was told I should have had another 5 Hp or so. Based on that alone, I think you
should expect at least 40 Hp at the rear wheels from a 1500 TP.
I think the list Hp for a 1500 SP is 54 Hp at the flywheel. :thumb
BTW hows the economy on that cos my 40hp was very economical do they drink a lot the 1500's?
Shouldnt drink that much more.
You have a anerexic(sp?) car to start with
It is the lard arse super beetles that drink more cause they weigh more.
(guess you have to pay for good looks - eh!)
hehehehe cool cant wait come past Barry if u want we are doing it on Sunday
:beer
Lets see what we have here,according to the dynoday figures all the 1600s did from 38-39 horsies std,with a webber add 2 more.The 1500s one did 34 and
needs attention ide say and one did a very healthy 40 bit suss there either fresh rebuild or something non stock,so im guessing 37 galloping stallions
and 85% more power then Pat and Jens cars.No flames intended,
