Hi all,
I'm fairly new to this site and I was wondering about motors. More specifically, the relationship of motor size/output compared to NSW road legal
engineering upgrades.
for arguments sake say I was to upgrade a '65 beetle from its standard 1200 to:
a mild 1600tp
or 1776
or even a 1915/16... or BIGGER?
(all of these would have exhaust and twin carbys of some sort).
would I need an engineers certificate for any or all of these choices?
at what point do you have to (legally) upgrade:
the brakes, from the standard drum - the suspension - seatbelts - windscreen wipers - to something better?
any advice would be greatly appreciated,
Thanks in advance
ok the biggest engine size without an engineers is 1700 for a bug.
Beg to differ Barls
1700 is correct if you are working from a 1600
I am 99% sure (in NSW) self engineered is a 15% increase
So - based on a 1200 you are looking at a 1380??
That said - bugger all people would know the difference
As for the brake upgrade - again in NSW - once you upgrade to a 1600 you need the equivelent brakes
ie discs up front
Legeally - you really are better off going with a later pan that already has a 1600 and discs as standard
or just get it engineered
Upgrading the brakes is just common sense
Suspension - just needs to be in good nick
Decent shocks and good bushings/ball joints / K&L pins all round
You also need to think about a later gear box
A big motor and a 1200 box is a headache
Cheers guys, Bizarre that helps alot.
I was thinking about changing the pan, it would make sense...
but, I kinda like the idea of keeping it mostly stock except for a bigger motor/gearbox/ etc. That and I'm a fan of the wide five wheels (I know its
a silly reason for not doing the obvious upgrade, but, meh).
will a 1500 gearbox fit in a 1200 pan? (it should)
As for the brakes does anyone know of a wide 5 disc conversion in Australia?
I've found empi ones in the US. Anyone have any thoughts on these?
I've been around veedubs since I was young bUt I haven't tinkered with one for about 10years...
with that in mind;
As far as gearboxes/ motors and other spares go who has the broader (cheaper) range in sydney?
Volksbahn?
Vintage veedub?
(Is tooleys still around?)
Any others I'm not aware of?
Will post up some pics of my project soon...
tooleys is still around and quite helpful there is also fermans in penshurst.
Cheers Barls
