berg style midmount question
funbug - August 3rd, 2010 at 08:18 PM
Do you put the midmount directly against the gearbox casing or against the lower nuts with another set of nuts?
hellbugged - August 3rd, 2010 at 08:23 PM
done it both ways.......you will need longer studs
funbug - August 3rd, 2010 at 09:01 PM
Originally
posted by hellbugged
If you mount it directly against the casing won't it inrease your chances of oil leaks? I am aware of the need to fit longer studs.
Bizarre - August 3rd, 2010 at 09:39 PM
I did mine like this
Newt - August 3rd, 2010 at 11:21 PM
Bizarre
Does this sit further forward on the gear box than the Berg mount?
Newt
funbug - August 4th, 2010 at 04:29 PM
Bizzare are those studs which fit the cradle flush against the gearbox casing?
Euro_67 - August 4th, 2010 at 08:06 PM
They look like cap head allen bolts.
Bizarre - August 5th, 2010 at 07:29 AM
Yes - we took the studs out and replaced them with allen bolts
funbug - August 5th, 2010 at 12:23 PM
Originally
posted by Bizarre
Do you have any problems with oil leaks?
Joel - August 5th, 2010 at 12:57 PM
Just put some Leak-loc on the threads, I did this with my 70 bug, it has the same setup
