IRS Geometry Question
Newt - August 16th, 2010 at 11:12 PM
Hi guys,
Just wondering. On a IRS A arms, are the stub axels from the various modles all set at the same camber?
Im trying to work out if my A arm is a bit twisted.
Newt
1303Steve - August 17th, 2010 at 08:06 AM
I'm sure they would be all the same, if they're bent you can sometimes see stress marks in the paint.
matberry - August 17th, 2010 at 09:01 AM
Yep, all the same imo. If camber is off, and diagonal arm is not bent, can be the pivot bushes worn.
