a freinds dad wants to build a low revving torque 2165cc for his split bus..doesnt want a revvy donk,just something with low down torque and can tow
his dingy around....the budget is enough to build a more hi po motor but dont want to spend it on unecessery items....
so anyone with some good advise about a nice combo on heads,cam,carbs,exaust,etc would be great..we have a rough idea on a combo..
so this is what we are thinking
heads: steve timms stage 1's..but thinking could get away with single hd springs...."maybe to much head"??
case: std mag bored for 94mm
intake: kadrons or 40mm idf or dells
cam: engle 110 with some slr treated lifters
cam gear: ?????
rockers: solid shaft 1.1's
pushrods: steel or ali ??
flywheel: cast or forged stock weight or lightened to 14lbs
crank: 78mm cb race ready
exhaust: merged 1 3/8" quite phat boy
clutch & pressure plate: ????
not sure on which brand of bearings etc to get
http://forums.aussieveedubbers.com/viewtopic.php?tid=76393
If you check on page 4 it gives the specs of the engine in my Kombi. Could not be happier with how smoothly it drives and the power on demand. If you
were really keen to have down low as the major priority you would go back to the Engle 100 I think. Not that I am ever unhappy with the down low
response of my engine. Good luck - have fun
cheers vassy.....
What about a type 4?
Not sure how that goes in a split
Should imagne fairly easy with an upright conversion??
Holzl (V Force) does a lot of 66 crank x 103 pistons to make a "simple" 2.3L (ish) motor
basically a stock 1.7/1.8 bottom end with a P&C kit
If you are coming to Warwick I can take you for a spin around the block. That speaks more than a thousand words could say.
all good vassy, too far from perth.......but thanks anyways......
