i am considering buying front and rear cross drilled disc brakes with twin piston willwood calipers from airkewled has anybody used these are they worth the outlay or are there any brake systems from australia that are of same or better quality and performance
There was a similar post regarding a Type 3
Richard Holzl @ V Force does a Porsche Boxster kit for the front and I think Ford EB for the rear
Give him a call on 0408 991 247
B 4 u start spending all that money
What car and year model n engine size do u have
U may not need that much stopping power
How about the set up that vwcool designed. There is a thread somewhere on here. They looked like pretty serious upgrade without the outrageous price tag.
also - good luck getting MOST wilwood calipers approved, almost none have dust seals which you will find is one of the req's for rego/approval
probably in every state
+1 for the vwcool or v-force options if you need them
i have a 74 std beetle want the added stopping power as i am considering doing track days here and there and maybe at some stage do some hill climbs if driving skill develops. will be running 1916 engine probably built by pobjoy
