Can anyone tell me how i could measure the stroke of a crank that is not in an engine atm. I have a set of pistons and cylinders and want to work out
the capacity of an engine.
Pistons are 94s but have no idea what the crank is.
The stroke is twice the distance between the centres of the main bearing and the big end bearing, measured radially.
Thanks for that waveman. That's what I thought but had been told by a mechanic that I could only measure it set in a block.
Problem is I would need to pull down an engine to do that. The crank was given to me with the piston set none of them attached to an engine block. I just want some idea before I begin pulling down an engine so I can make some decisions over which engine I will be putting them in. Thanks for info.
Aftermarket cranks sometimes have the stroke punched or cast onto the crank web in small numbers somewhere.
If not it's reasonablly easy to measure, thanks to the fact that VW cranks lay flat.
Get a sheet of A3 paper and lay it on your bench, and lay the crank flat on top. Get a metal set square and a sharp pencil. Put the set square on the
paper and place against the outer faces of each of the big end journals. Mark the paper - you are dropping a line directly downwards to the paper.
Now do the same with the inner faces of the four big ends. You should now have eight marks on the paper, indicating the inner and outer points of each
journal. Carefully rule four lines lengthways, between the two outer points on one side, the two inners on one side, the two inners on the other side,
and the two outers on the other side.
Now measure acrossways to get the stroke. Measure between the two outer lines, then between the two inner lines, and average the result. That's the
stroke.
You can cross-check by measuring from the outer line on one side, to the inner line on the other side - and vice versa.
This won't be to aircraft or space shuttle tolerances of course, but if you're careful you should get an answer to the nearest mm.
