Has anyone come across the little rubber grommets that go in the steering box cover? or the end cap to go on the steering box in the opposite end to
the shaft of the worm drive?
Not sure if there available but have just rebuilt box and mine are shot!
also looking for these, curious if anyone stocks them, failing that ill suss out the automotive rubber & trim supples shop up the rd for something suitable
Brake shops use these plugs on wheel and master cylinders. Should be able to get some off them.
I have taken mine to CalOffroad. They are going to machine a few parts up for me. I bought a steering box rebuild kit and it was missing some of the parts I thought would be in it. I need to get some gasket paper to cut into shape also!
does anyone know what the grommets are for? Are they to let the steering box breath? Could you block them?
