Oil lamp comes on at low idle after engine warms up.
benjicon - January 4th, 2011 at 12:01 PM
Hey guys,
New problems to tackle for the new year.. HOORAY!
Heres the scenario, Start the car up from cold, every thing is fine, drive for 30 mins, oil lamp starts to flutter on when I stop in traffic and let
it idle, when I take off again lamp goes out, this continues to get worse as time goes on, if I am sat in traffic idling and I rev the engine, the
lamp goes out, but I need to keep the revs up, this continues to decline to the point where no matter how many revs I give it the lamp stays on.
Needless to say I am not driving it much now this has started. If I have to, its only for short trips before the lamp starts coming on.
This started happening after I had it serviced 3 weeks ago, I know its an old motor and needs an overhaul soon, but could it be that the mechanic put
too thin an oil in the motor for its age? (I think they put in a 20-50w).
For an old engine with worn bearings, rings and seals etc, would a thicker oil possibly remedy this problem?
I am hoping for a temporary solution that will get me by till I can afford to get the motor overhauled.
Thanks as always for any help.
Cheers.. Ben.
ian.mezz - January 4th, 2011 at 12:30 PM
I would check the oil level.
then a cheap thing to do is to change the oil to Valoline 20/60 for worn motors.
ian.mezz - January 4th, 2011 at 12:33 PM
O Yeah make sure the cooling fan is working, cause if the motor gets To hot the oil thins out to .
benjicon - January 4th, 2011 at 12:39 PM
Thanks mate,
Oil level is fine, pretty sure the fan is fine too, but I'll double check. Cheers.
waveman1500 - January 4th, 2011 at 06:04 PM
On my old tired engine I used to run Penrite HPR50, which is a 40W70 mineral oil with good additives for old worn engines. I found that the engine ran
much happier on it, it quietened down the bearings so that they were no longer audible over the sound of the engine (!) and it ran very happily for a
couple of years, including being thrashed in motorsport events. Your engine may have other problems, but I would definitely recommend trying a heavier
oil if you think it's fairly well worn.
DylanTheDubber - January 4th, 2011 at 06:42 PM
Check the oil pressure put a gauge on the motor and find out if you got good pressure if that fine and the oil level is fine you got a problem on the
wire.
From Dylan
benjicon - January 4th, 2011 at 08:07 PM
Originally
posted by waveman1500
Thanks dude, the old girls definitely old and worn, its the OG 36hp that was removed and replaced by a newer motor, the og was serviced and put back
in before i bought it... I dont think its ever been rebuilt.
I just read that Repco down the road has the Penrite 40-70. I'll shoot down tomorrow and get some and put it in, I cant see it doing any harm.
Cheers again mate.
Craig Torrens - January 4th, 2011 at 08:53 PM
you could always fit a 30mm oil pump to boost the pressure.
68AutoBug - January 5th, 2011 at 01:55 AM
Originally
posted by benjicon
Hey guys,
Cheers.. Ben.
it seems Your oil is too thin when its heated...
make sure the thermostat on the back fan is opened up..
I would also replace the oil sender... very cheap...
when the oil is thick it doesn't go thru the oil cooler until the oil gets thin and then the oil pressure releif valve allows the oil to flow thru
the oil cooler...
thicker oil can't hurt... IMHO...
Here is a diagram of dual oil senders - You only have one...
so do I... lol number 1 in Diagram..
http://rides.webshots.com/photo/2427960210050767931EyKmMr
matberry - January 5th, 2011 at 08:07 AM
Originally
posted by Craig Torrens
Not in a 36'er....Doh!
Craig Torrens - January 5th, 2011 at 08:11 AM
Originally
posted by matberry
Why not ?
Joel - January 5th, 2011 at 08:33 AM
One thing to consider seeing as it's the OG 36er is that bandaid fixes like thicker oil, bigger oil pimp etc just to keep it going that bit longer
may turn around and bite you in the arse.
Memory is abit hazey on 36s but I'm sure the cam doesnt run in bearings, and if the case flogs out too much you may end up pushing it to beyond
rebuilding which would be a shame seeing as the rest of the car seems very original too
Craig Torrens - January 5th, 2011 at 01:44 PM
^Agree.............if it was mine I would have stopped driving it well before now, like when the light first came on !
Oh and I don't know of anyone that can line bore the cases either, so if it gets "flogged out" its a throw away case
