Ok, I just need some advice due to Aust being parity on the $USD. I am looking at getting some performance parts in for a motor build later on. I
would like some head advice and on the cost effectiveness of the build. I have done some reading and have established that you need to buy heads
before camshaft as you select the cam to suit how you drive and where you want power, but with head selection is there such a thing as too big no
matter what cam is selected?
I am leaning towards at a set of CNC ported 044’s (wedgeport or the like) or DRD racings selection but in some readings people have mentioned port
velocity losses and so on at the valve. Would it be wise to get something large and sore them?
My motor build is looking like a, within reason, HiPo 1916 (or stroked if I can keep motor width normal), with the possibility of forced induction (I
am in mock-up stage at the moment). I would like to keep my budget within limits so if I purchase things as I go the savings make it worth it for the
larger purchases. I am looking to get the best heads I can for $1000 approx landed as I would like to avoid duty if I can but who knows if I find the
right ones.
On the other hand is it worth just getting something built here or buying one off Penrose, are builders just paying American retail and adding postage
and a percentage or are they purchasing at trade/wholesale? If the latter I would not mind giving them my business as I don’t want to pay two lots
of retail tax and duties. I would love to just get something built later rather than do all this stuffing around (including them getting the heads),
that would be nice but if I can save some money for other go fast parts who could blame me.
If I could get some realistic advice from established builders and racers (like Rod Penrose) who have tried and tested builds on motors and have a
realistic understanding on what a motor can and cannot do (sorry to the keyboard mechanics) it would be very helpful in putting my mind at ease.
So to sum my rant up, buy as I go (and here the head advice would help), or buy a complete longblock later?
Find your builder, then talk to them and see what their suggestions/recommendations are.
Around Brissy and from personal experience I'd recommend Dave Butler (on here as dangerous) - he built my 1915 with 044 Wedge Ports, 11:1
compression, FK87 etc ...... it gives pretty healthy hp figures
I know a couple people who've had good results with Matt Berry (on avd also) as well as Leon from Leon's Motors, so also worth a call.
A thousand ways to skin a cat, but pretty sure they'll all tell you it's the combination... best to have the complete plan before spending any
btw - race car, street car, or a mix ???
My advice is to ring Rod, tell him what you are after, I got a 2176 (78.4x94) off him a while back at a great price. If its set up right ie all machining done, correct rod length etc then you can have your cake and eat it too, mine measured up at 2mm wider than a stock 1600tp.
yeah, i second that you cant go past rod.... looking at his prices for alot of things its almost like he generally charges what he pays for things in the US but doesn't seem to charge much freight US -OZ, i think its because he fills containers and pays a flat rate on shipping it all back here. He'll certainly be the first call i make when i'm ready for a motor....
yep talk to Dave or Matt if yr in Brisbane
what fuel do u want to run thats a big point
Talk to Craig Brown at Crankshaft engineering in Brisbane, he has built hundreds of engines over the years and go back a long way to manx buggies when
it was owned by Tom Pootes,
Has all the machines in house and has excellent knowledge on vw heads
Looks like I have some phone calls to make and see if it’s better for me to purchase parts under their guidance and build when I have them all
together (spread the cost and save with parity) or just get them to build a complete longblock.
I just want to run pump unleaded, the type will depend on build I gather.
Thanks everyone that commented, but keep your experiences coming. I can only think that there are others with this swilling around in their heads.
Cam
It's a big subject with heaps of variables to take into account. Best to call a few builders and run with those you feel comfortable with, most builder's will have their own ideas or variations to what you 'need' or what 'works'.
