Just a question about carbs, are the EMPI BROSOL DUAL 44MM CARB KIT WITH 12 VOLT ELECTRIC CHOKES, going to work as well as a 44mm idf carb kit for a 2007cc stroker motor, or should I just buy the 44 idf carbs?
buy the real webber you wont regret it in the long run. the brosals have had porosity problems, ie they are two porus
http://forums.aussieveedubbers.com/viewtopic.php?tid=87639&page=1#pid816973
Go IDF, those are single choke, like a big pair of Kadron's.
