1916 turbo
justkampers - March 10th, 2011 at 08:57 AM
hey guys and girls just a quick question what size turbo would you recommend for a 1916 with a 130engle cam would you recommend a t25 or something like an ihi unit
justkampers - March 10th, 2011 at 08:58 AM
also its mainly for strip
ian.mezz - March 10th, 2011 at 09:56 AM
ask hypo-vw
justkampers - March 10th, 2011 at 10:15 AM
cheers will do i have already had a 1776cc with a GT17 on it which was not to bad but never played with a 1916 thats all
Joel - March 10th, 2011 at 11:23 AM
You'll need something fairly decent in size, cos that's a shitload of cam for a turbo engine.
lucky it's for drag.
justkampers - March 10th, 2011 at 11:27 AM
i have 110s on the shelf but ordered in a 130 to see how it will get up if not go back
Ollie - March 10th, 2011 at 01:03 PM
Agreeing with Joel here, a 130 is enormous. Still, It'll make some pretty spectacular power figures!
Could be well off here, but a t25 or t28 could be a good start?
SuperOwen - March 10th, 2011 at 09:02 PM
More info on the engine, heads etc. Do you have a target HP goal?
justkampers - March 11th, 2011 at 07:38 AM
heads will be hemied to decompress it to the max and just a slight clean up of the ports and such engine its self is a basic 1916 turbo not sure of set up have had alot of luck with blow thru but see so many done suck thru
mactaylor - March 12th, 2011 at 05:13 AM
disco potatoe
