indicator switch
71dub - March 11th, 2011 at 09:44 PM
Hi guys i have a 1971 super bug with the indicator switch wiring disconected .i have seven wires that are not connected to anything.the wires are as follows
1 Brown
2 White
3 Grey with Black stripe
4 Black with White stripe and Green rings
5 Black with white stripe
6 Brown with white stripe
7 Black with green stripe
if some could help and advise where these wires go would be appreceated .
regards barrie
pod - March 11th, 2011 at 11:27 PM
try here for a wiring diagram
http://www.vintagebus.com/wiring/index.html
Joel - March 12th, 2011 at 08:00 PM
The wiring of new ones doesn't usually match the old German ones real well.
Can you put pics of the front and back of it up?
for the indicators:
black with white and green trace is indicator signal from the flasher relay
black with green is the right indicator output
black with white is the left indicator output.
The brown will be an earth.
2 of the others will be the horn and the highbeam relay output
brown with white trace is usually the highbeam
Sounds like it may have extra wires for the euro side marker system which isnt hooked up in oz.
71dub - March 13th, 2011 at 04:01 PM
hi joel please see attached photos .wires come straight out the back of the switch then up under the dash the the fuses box and where the wires attach.
71dub - March 13th, 2011 at 04:03 PM
first photo
second photo
71dub - March 13th, 2011 at 04:04 PM
third photo
Joel - March 13th, 2011 at 08:05 PM
It will be easier to pick if you remove it and see at the back where the wires are coming from like below
As I said though the indicators are easy then you just need to find the highbeam and horn wire
http://images.thesamba.com/vw/gallery/pix/647668.jpg
71dub - March 13th, 2011 at 08:21 PM
Hi joel hope these help.
regards barrie
71dub - March 13th, 2011 at 08:23 PM
here is another photo
