Put it back in your pants. I'm after some metric studs to mount my Holley progressive with an aluminium spacer. the ones I have are too short and I
have no idea where to source studs from.
Can someone tell me what sort of place I can buy them from?
Thanks.
go to your local hardware and buy a meter of allthread (booker rod) then cut them the size you want,either that or a fully threaded bolt to the length
you need and cut the head off and dress up the end ![]()
Your other option is to go to an exhaust shop with your sizes and purchase them ready made.
Hardware store threaded rod is usually pretty terrible low-grade stuff and made of cheese. I'd buy studs from a proper engineering supplier like CBC or someone like that.
well it is only for holding down a carby,and he lives out in the middle of the country,didnt think of exhaust place grumble
The hardware store ones are usually imperial thread.I'd have to tap and helicoil probably if I used them.
No exhaust places for about 100km. There's a store that sells ...stuff. various bolts fittings, some tools, wiring things, motorbike, generator etc.
parts, welders, camp fridges and whatever. Possibly them. I think there's a tractor supply place,a couple of small hardware stores, a plumbing and
miscellaneous place, and I don't know what else. help me here are type 4 exhaust studs larger diameter on one end than the other? if not they may do
it.
Once I get these studs sorted and pick up the manifold gaskets from the mechanic I'll be set to install. I wasn't game to make them myself because
the coolant runs like 5mm away from the manifold. Yes coolant. Check the sig.
I made up the carburettor / spacer gaskets this arvo. Only took me a few minutes. Fit great too which was good because there was more guesstimation
than I'd like to admit.
Just for the sake of running up your monthly data count:
Here's the spacer. I pulled that stud both because I got things stuck and I wanted a length reference.
Here's the manifold with carb and spacer sitting on it:
Spacer and quickie homemade gaskets:
OK what size threads do you need,if they need to be stepped what size each end and what length.I have some T4 O/S exhaust studs,from memory they are 10mm one end and 8mm the other,not sure of length.let me know what you need and I may be able to help. Cheers Les
Standard 8mm thread is 8x1.25.
Try some old engine or gearbox studs if you cant get to a shop.
I wish i had a spare gearbox! Anyway I asked around today and found that the mechanic has a stash of studs. Got some nice uneven threaded ones which were perfect for the job. I did however discover that the carb base holes had been drilled a fraction crooked which made getting the spacer and carburettor on a bit awkward (understatement) but it's assembled now. It'll have to be pulled apart again but I won't bother until I get a thermostat and gasket to finish preparing the manifold. I also need to plug some of its vac lines and remove a useless gable guide bracket. The engine bay should look a bit cleaner after this at very least. The engine should run better too.
