oil cooler
1916baja - April 10th, 2011 at 07:58 PM
Hi guys,
If i'm running a brazilian as41 case with an old doghouse fanshroud which oil cooler do i need? late or early? and do i need an adaptor?
Mick.
johny rotten - April 10th, 2011 at 09:17 PM
late type 1 cooler with OEM bracket
68AutoBug - April 11th, 2011 at 08:00 PM
Yes the bracket/adaptor comes with the doghouse oil cooler unless You buy a new one... lol
don't use an early oil cooler with a doghouse shroud..
make sure You use the later doghouse fan also....
1916baja - April 11th, 2011 at 08:13 PM
Ok so i should be able to dig up and old oil cooler with the bracket attached,remove it and just get a new late model cooler? later doghouse fan.. got it.
