Is a phat boy muffler similar to a sidewinder?
Not really. The Phat Boy is just a muffler, which bolts on to the standard three-bolt header flange used by most bug headers which merge in the middle below the rear valance. The sidewinder is a header which merges horizontally across the rear of the car behind the valance and exits sideways into a muffler under the RHS rocker cover. I bought one at Day of the VW SA and it sounds great!
thanks for that which did you buy a phat boy or sidewinder
I'm looking to a buy a new exhaust system soon, and was throwing up between these 2 as well. Just wondering would there be any installation problems on a 1600dp, with the rear apron exhaust cut-outs filled in? I'm looking to upgrade to twin carbies in the future, so i would like something that would hopefully compliment the exhaust in regards to power increase.
I'm pretty sure both styles do not utilise the original cut outs.
PS apparently there are sidewinder exhausts and there are side winder exhausts... check where they are madeand quality
Sidewinders are built abit more performace orientated than than a fatboy and a 4into1 header, the collector is properly laid out in the correct firing
order.
I've seen someone on the samba who has modified a sidewinder to fit stock cutouts
This is a stainless steel copy that i got from George.
I have the stainless steel sidewinder also, like vw060.
Vollks.com.au are getting sidewinders in stainless steel in a few months and i will get one ceramic coated
