Oil cooling
lowrider - August 1st, 2003 at 08:42 AM
Just scored a 1600tp with a fitting for a remote oil cooler instead of doghouse cooler(it was fitted to a Baja) Is this the go for better oil cooling & air flow around cylinders 3&4; if so,
where would you mount the cooler element in a Ghia?? Any tips?
thanks Andy
Stanley - August 1st, 2003 at 12:34 PM
Ditch it. There is no better stock cooling system than the dog house cooler. It would work ok on a baja as the have no back, a ghia on the other hand would be trouble. Have a look at any big site.
Berg for example has experimented with all types of coolers and settled on stock cooler setup. Use an external cooler if you must to assist the standard set up but I wouldn't run it on its own.
lowrider - August 1st, 2003 at 02:04 PM
Understand..... thanks a lot
Anyone got a doghouse cooler and fan shroud?
I have 12v generator
Andy
