Hi there,
I have a 66 beetle I am trying to get running. I put the engine in on the weekend, cleaned out the fuel tank, replaced the rubber hoses then thought i
would run some fuel through the line to make sure there wasn't any crap in them and low and behold the steel line is blocked!
I tried compressed air through the line but can't even get air throught it. Has anyone ever replaced the steel fuel line before and if so how is it
done?
Brad
Replace is doable but you should be able to clean out the old tube. Poke some wire in and if it doesn't work an old clutch cable in an electric drill will shift anything in the tube.
have you checked for a fuel filter, they can find funny places to be use
