Can anyone help in identifying this clutch?
Is it 200mm,it may be a kombi or a type 3.It will have a part number around the outside of the pressure plate This shouldn't matter which it is as it will only be a little heavier in the clamping pressure.
Part No. 211 141 625A and also has F & S on it. Will this be too heavy - as it is for my daughters Beetle?
It will be a kombi unit and will require a bit more pedal pressure than the standard unit. The answer to if it will be too heavy is a tough one as it
depends on the driver but I would think she would take it in her stride if she is a competant driver.
