It probably been asked a million times but, What electric fuel pump would suit me the best? 1916cc 44if webers, will be used in a drag racing
application. Not a hot drag motor, just a fairly hot street motor. I'll be placing an order a classic veedub soon so it would be handy to get it from
him, are either of the ones he sells ok? should i be using a regulator? the little kit with pump and block off??
Mick
just get a rotary one from repco, regulated to the pressure you need for the webbers.
you just use the vw fuel pump and stock fuel pipes no probs.
this is rose @ Portland stock vw pump and stock 1954 vw fuel tap
http://www.youtube.com/user/avwnut#p/u/22/Ah2AZ1-FxeI
ask classic for the chrome vw pump they work fine.
