Splitty Oil Leak
64Samba - August 9th, 2003 at 08:53 AM
Hi...
May 64 splitty has developed a bad oil leak at the engine/gearbox point somewhere. ( cant tell where exactly as its all caked in oil/grime) I know its not engine oil as the level hasnt gone down..
Its still running the original reduction boxes etc.
What seal could it be? Any help?
Jay
Bizarre - August 9th, 2003 at 09:25 AM
at the engine/gearbox point somewhere - i would be it is the front engine seal. It is behind the flywheel. It should be leaking slowly at the gearbox engine join.
Engine out job. Actually its a "may as well do the clutch" job
