This is probably a dumb question, but is the hole in the base plate of the air cleaner for the oil breather tube:
I'm referring to the hole in the top right hand corner.
yep
^^ What Ian said...
Thanks guys. I have dutifully inserted hose B into hole A.
that hole should have a small hose fitting in it,
Where would I get a hose fitting from?
Yeah, definitely need a fitting... otherwise you've got a way for air to get in without going through the filter first.
For a hose fitting... Bunnings or SuperCheap is a possible, but more likely a Repco... you just want a 90 deg barbed fitting for that size hole and
hose (so take both hose and air cleaner base with ya)
