Have been reading a little about this on thesamba, and wondered if anyone on here has put a 356 cooler on a VW?
I'm talking about the single relief style cases 1300 (F series and before)
Can it be done?
Anyone tried it?
Any good/better?
Reading online the NLA cooler seems to be the best one going, for me it would be a great way on increasing the cooling whilst maintaining a more
period look, it also seems to improve airflow to the 3,4 side of the engine.
Shaun
Links ?
Hi Shaun
Anything for a 356 will cost dollars, you could easily fit a doghouse cooler and fan shroud to your car or an external cooler.
Links
http://www.nlaparts.com/store/aluminum-cooler-p-691.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=141351&start=0
Hi Steve,
Yeah I know that anything with a 'porsche' badge on it will cost more but i'd like to do something a little bit different from normal, as the car
is supposed to represent a racing period of 1965 and before and the dog-house wasn't around. That said the 1300 twin port heads I have weren't
around, and also the kadrons; but these are substitutes for okrasa or denzel heads and Solex 40 PBIC or PICB carbs.
Do you think the doghouse would be better?
Shaun
thinking about it, the cost in coverting the old tin and getting a decent external cooler would be the same or more than buying a new 356 cooler.
Hi Lee,
The 356 parts arn't too bad to get, if I was getting an original one then maybe but i'm looking at the gucci aluminium ones.
Weight is also a factor with this so I would like to avoid an external set-up (waiting for the jeers on this one)
Shaun
http://forums.pre67vw.com/default.aspx?g=posts&t=16265
interesting read, this fella found the 356 cooler lowered oil temp but increased the 3&4 cylinder temps....
looks like I might just keep the stock cooler and see what happens
easy to go to late style doghouse cooler. i've done it a couple of times
just enlarge the two bolt holes in the case for the bigger bolts of the late cooler.....remove, drill and tap the stud on top of the case for the 3rd
location on the cooler....also larger
order some "adapter" seals from vintage vee dub that accomodate the early case on on side and the late cooler on the other (i have some if they
don't stock them at the moment)
change the fan housing, fan and rear engine tin to accomodate the doghouse coolers "exhaust"
bob's your uncle!
I had trouble free run with it like that
I like the cool factor but have to agree for engine longevety the dog house would not effect 3 & 4 like the stock early setup.
You can borrow a late 912 cooler from me and see how it goes if you like.
- don't see why there should be any overheating issues with 3 & 4 - the standard 912 runs about 90 engine horsepower without probs with much the
same tinware. There are a couple of other 356 cooling tricks that might work on a race engine.
http://www.thesamba.com/vw/forum/viewtopic.php?t=325346&start=0
fuel for the fire, both Lance and a fella on this thread make a good point, that 356's and 912's ran these coolers at much higher speeds and HP and
never had an issue over heating 3&4.
http://www.airflow-systems.com/
apprantly this is the ducks nuts of coolers, pricey though...
