where can i get high tensile bolts
cam070 - November 9th, 2011 at 12:30 AM
As the title says, I was wondering if anyone can recommend places where I can source high tensile bolts in small quantities. Specifically I need tapered flat top Allen bolts for door hinges.
Happy to pay postage if they can supply for a fair price.
homer - November 9th, 2011 at 04:53 AM
If you are anywhere near South Windsor try Buttsworth Industrial Supplies
vw54 - November 9th, 2011 at 06:05 AM
you can buy from VVDS 9789-1777 they have the door hinge bolts
cam070 - November 9th, 2011 at 07:43 AM
Sorry, it's not actually the door hinge bolts I am after, these bolts will replace the factory rivets that need to get drilled out.
cam070 - November 9th, 2011 at 12:58 PM
In case anyone is interested I called my local auto shop and they put me onto these guys:
Mitchell Engineering Supplies who are happy to supply small quantities, http://www.mitchellsengineerssupplies.com.au/
Best part was they were local.
Another suggestions was Inox Fasteners, http://www.inox-fasteners.com.au/
Hope this might help anyone else out there.
1303Steve - November 9th, 2011 at 06:25 PM
Nearly every suburb has a nut & bolt shop, your location would help.
I use Industrial Fasteners in Mortdale 02 9534 6844.
t1 time - November 9th, 2011 at 06:42 PM
Fred Tapping .Ingelburn,
pod - November 9th, 2011 at 08:43 PM
For work we use Component Engineering at Revesby,or there is a lot of Coventry Fasteners stores about ,we use the one at Minto
