Hi,
The original engine from my Beetle will shortly be removed. You can tell how original it is by the diagnostic plug sitting there unmolested and the
tar board still in good nick despite its 37 years.
Purists would cry that I'm pulling it all out if it weren't for the fact that it's a Superbug!!
Anyway, rather than stick the daggy tarboard back in, I'm considering other options. What I don't want is:
* More tarboard, because I'm going to be putting carb access panels in the side.
* Stainless Steel firewalls, because I just don't.
What I am thinking of is this:
http://www.dynamat.com/products_automotive_hoodliner.html
What are other people doing, or do you not do anything and just have the painted metal?
Craig
as You will see in many car shows...
many people go for the bare metal look..
but its much better to put something in there and dynamat is an excellent product
I did all around and under My engine bay and above the gearbox with the PVE yoga mat type of foam.. and painted it matt black
You cannot actually see it... I do however have the stainless louvered rear firewall piece on there...
If You use dynamat everywhere You will end up with a very quiet car ...
Quote: |
i used dynomat on mine.
heres a thread on it
http://forums.aussieveedubbers.com/viewtopic.php?tid=86816&page=2#pid8716... are heaps more, just search dynomat.
Quote: |
your new motor will be noisey , so I would go with the dynomate stuff, the new after market vw tar stuff that you can buy for your bug doesn't hold
its shape .
and the steel look doesn't stop the noise,
I would also fill your back seat with some foam from Clarke rubber.
Painted steel may look good but lets heaps of noise through. Mine is currently bare because the tar board came loose and sucked on to the fan so it
had to go Although I havn't installed it yet, I bought some boat engine noise insulation from Whitworths. It is designed to quieten down inboard
motor noise in powerboats. It is peel and stick one side, layer of tar like stuff then layer of acoustic foam then fairly thick aluminium foil on the
outside. Looks to me like it might work ok
Foam in the back seat also sounds like an excellent idea. The engine noise without any seat is very loud, so a seat plus foam may well make a big
difference.
Cheers....wayne
Thanks Guys,
Yes, the engine bay is only part one. Once the money tree regrows the entire interior will get a refurb with Dynamat everywhere, soundsystem, carpet,
headliner, new back seat etc etc etc.
I think that will probably be at the back end of next year.
I just figured it's noisy enough inside already and given the tarboard will be gone and the engine bigger the noise will be greater, so I'd better
do something while the engine is out.
So Dynamat underneath, then the hoodliner, then down the track all the extra goodies inside.
Quote: |
Thanks Jeff. I better get round to installing it now I know it works
Cheers.Wayne
Jeff whats it called and emma chisit? Mitchell
found it
https://www.whitworths.com.au/main_itemdetail.asp?item=80200&search123=so...
Quote: |
The question I have about the marine stuff is whether it also reflects heat. Nothing in any of the blurb mentions it, but in the Dynamat stuff heat reflection is specifically mentioned.
Quote: |
