oil cooler hose came off... at 100 kmh..... No Oil... GREAT NEWS - ENGINE OK..
68AutoBug - November 24th, 2011 at 06:15 PM
Well
My oil cooler hose came off at 100 KMH a couple of days ago...
My fault.. clamps weren't tight...
I felt a Power Loss and a drop in speed...
looked out My rear vision Mirror... BLUE SMOKE...
so I turned the engine off and pulled off the highway..
looked under the back and a big pool of engine oil...
My first thoughts were the oil cooler [temporary] had hit something.. or the road....
but I let the car run down the hill and onto a side road where I jacked the car up, took the wheel off and found the oil cooler hanging by one hose..
and a tie down...??
I rang My wife to bring Me some oil... so I refitted the oil cooler and filled the engine with oil....
and drove back home... car goes and idles but its like it has some fouled spark plugs ...
I checked all the tappets today... all correct...
I was on My way to get My car passed for rego...
do I drive the 30klms next monday and have the car passed before I pull the engine out and pull it apart???
what are Your thoughts????
looks like all the oil galleries are still clear???
vwo60 - November 24th, 2011 at 06:41 PM
Is the engine noisy, knocking of any kind, check the oil pressure, check the plugs, did the engine ingest the oil through the air filter, it pays to
spend money on good braided lines with the correct JIS/SAE fittings.
h - November 24th, 2011 at 07:01 PM
oh pooh
not good but how did u forget to tighten up themes hoses?
sounds expensive
bingo for the pic as I was looking for it covered in oil?
I wonder if magnateck would of held it all together??
put some moreys in it n it should be fine maybe
dangerous - November 24th, 2011 at 07:04 PM
If it was slowing its self down it will be shagged.
Time to get rid of all that extra bolt on stuff Lee.
Stock engines dont need it.
"parts left out cost nothing, and cause no service difficulties"
Craig Torrens - November 24th, 2011 at 07:05 PM
It pays to just use a VW cooler and scrap the external crap
vlad01 - November 24th, 2011 at 07:30 PM
all the bearings and journals a fuched! especially with castrol stuff in it
yeah it will need rebuilding since it lost power and engine speed when it happen.
Smiley - November 24th, 2011 at 09:28 PM
Did you not notice the oil pressure warning light when it came on??
Smiley
vwo60 - November 24th, 2011 at 09:43 PM
absolutly nothing wrong with external coolers if they are done correctly, i would like to see some of the high horse power engines run with only the
dog house cooler.
Craig Torrens - November 24th, 2011 at 09:48 PM
I only run with the dog house cooler.......but I only have around 140hp atw
Like you said, coolers need to be of the right quality and installed correctly.
68AutoBug - November 24th, 2011 at 11:01 PM
Originally
posted by vwo60
Worst part is... I have a new doghouse oil cooler to go in....!!
No knocking or noise at all...
just low in power... plenty of compression when turning the crankshaft pulley to check the tappets...
I will check the spark plugs...
the oil went underneath the car all over the RH side of the exhaust and muffler...
although most went on the ground when i stopped...?
I didn't notice the oil light come on...
I will Now have an EXTRA VERY BRIGHT oil light - so I will see it go on..
someone on here said they used the oil light to turn off the ignition if the oil pressure drops... I wish I had done that...!!
it would have saved a lot of problems and money...
Now I just need to get it passed for rego so I can pull it apart...
usually I check all hose clamps at least 6 times... and I used to double clamp years ago...
especially fuel hoses...
I hope You are wrong Vlad...
maybe the bearings are scored slightly?? all bearings??
Back to standard next time.... no more temporary oil coolers.
vwo60 - November 25th, 2011 at 06:40 AM
Its the hoses not the cooler
1303Steve - November 25th, 2011 at 07:07 AM
Hi Lee
Sorry to hear of your misfortune, maybe time for a bit more power twin port heads and 1776, would make a nice upgrade and the semi auto can handle it
OK.
I've fitted a double through relay to control a fuel pump, you could use it to turn power off to the ignition coil if you loose oil pressure.
87 not used
87A goes to the ignition coil
85 goes to the oil pressure warning light wire
86 & 30 are joined and fed by the ignition switch
On this relay when its at rest with no ignition feed, no power comes out of the relay at 87 or 87A
Turn the ignition on and the relay gets earth from the oil pressure switch, no power comes out of 87A, it only come out of 87 which is not used.
When the oil pressure builds the warning light goes out and the relay has no earth so it goes back to rest state but power goes through the relay at
pin 30 and on to 87A to power the ignition coil, if there is no oil pressure the relay is earthed again which takes power away from 87A.
Joel - November 25th, 2011 at 07:44 AM
Definately not one of VWs brighter ideas in flat windscreen beetles, using such a piddly little oil pressure idiot light that you need a magnifying
glass to see.
Even more so making it green of all colours in 68 and earlier bugs, what were they thinking...
I had a warning beeper on mine that was loud enough to be noticed while driving but not to be annoying everytime the ignition was turned on.
An oil pressure gauge is an invaluable tool though, I have fitted them in every VW i use on the road.
Driving down the road at 100km/h your engine is turning 3000rpm or more, by the time that light comes on at 3psi or less and you notice it and stop
the engine it's on borrowed time.
An oil pressure gauge you would catch it slowly dropping off earlier.
h - November 25th, 2011 at 08:15 AM
Originally
posted by Joel
glass to see.
agreed
I have volts, oil pressure n temp gauge in my beetle
I'm always keeping an eye on them while the little girl is barreling down the highway
much more accurate than the little man in the dash who lights the oil light candle when something is wrong
you get to know how things roll n if it isn't right you can spot it shut it down n check it out before the 'lee' syndrome kicks in n losses the
lot
invest in some gauges lee n set em up n I'm sure you can colour em pink or yellow to suit your attire
Joel - November 25th, 2011 at 08:27 AM
Originally
posted by h
Yep, all the colours of the rainbow.......Literally
chillihilli - November 25th, 2011 at 08:44 AM
Originally
posted by Joel
I'll second that. Whilst I don't have that much VW experience, I do have a pilots license
. Most light planes use a bigger version of a VW engine (flat 4 Continental or Lycoming). As you learn to fly you
are taught to watch the oil pressure gauge constantly. Its the earliest indicator of an impending engine failure as a symptom of a problem somewhere
in the oil circulation/sealing systems.
Here's an interesting story about reacting early to an oil pressure gauge reading low:
http://www.equipped.com/1199ditch.htm
Cheers Pete.
matberry - November 25th, 2011 at 08:52 AM
Gauges are good....but you have to notice them.
Sorry for your loss Lee
68AutoBug - November 25th, 2011 at 08:55 AM
well I have an oil pressure gauge which reads full scale as soon as the ignition is turned on....
so... another thing I should have fixed....??
Buzzer sounds great too...
bajachris88 - November 25th, 2011 at 01:32 PM
OHH NO! sorry to hear Lee,
Your story is typical of a veedubbers nightmare. Lets hope its nothing serious. Lucas oil stabiliser is great insurance for short durations of
complete lost oil pressure. I been using it in fear of a drained sump after all the fun with oil leaks i have had. Nuffin worse though then when the
crap happens to ya, and we all tell ya what you should have done which doesn't help ya right now lol, but i'm sure mate you'll get back on the road
soon. have you measured the compression on each cylinders? no chance of the piston rings just being a bit dry? (desperately trying to give some rookie
hints to excite some hope)
chillihilli - November 25th, 2011 at 01:54 PM
Originally
posted by 68AutoBug
If it didn't drop pressure when your hose came off then it's obviously faulty.. I think you've answered your own question... I've been thinking
about an oil pressure gauge. Do you have an oil temp guage? What did that say?
68AutoBug - November 25th, 2011 at 05:23 PM
Originally
posted by bajachris88
I haven't started it again since I drive it home...
with NEW Magnatech in it.,...
I'm sure?? that a bearing has been picked up... due to no oil and over heating [friction]
the oil temperature gauge didn't go HIGH... as I do watch it..
it was on about 60 or 80C degrees...
but once the oil drained out... the temperature gauge wasn't measuring anything...
Hoping for maybe New bearings and a crankshaft polish...??
as it wasn't an overheating problem... Air was still flowing over the cylinders etc...
but lack of lubrication = friction= heat .. and ??? YIKES..
Chris
I always pour some oil in the spark plug holes when I've had an engine apart - [ heads or cylinders/pistons etc.. ]
h - November 25th, 2011 at 06:55 PM
oh magnatech
nice one
it shoulda stuck on
vlad01 - November 25th, 2011 at 07:21 PM
Originally
posted by h
oh magnatech nice one
it shoulda stuck on
thats just marketing! most if not all oils have polarized chemicals that make it stick and wicks across metals to form a sacrificial surface.
It wouldn't surprise me if magnatec has one of the least of all brands.
ZDDP is one of those and magnatech doesn't have much of that.
omg
checked their site and they don't even tell the content on their
spec sheet and they how have a fuel saver magnatec? that definitely can't be good.
vwo60 - November 25th, 2011 at 08:33 PM
I would put castrol in my oil can.
68AutoBug - November 25th, 2011 at 10:03 PM
Originally
posted by vlad01
posted by h
oh magnatec nice one
it shoulda stuck on
ZDDP is one of those and magnatec doesn't have much of that.
omg checked their site and they don't even tell the content on their
The fuel saver oils started a few years ago in the USA..
Ford couldn't reduce their fuel consumption enough to meet the new USA laws... so they used 5w/10 engine oil [?? from memory] which reduced their
fuel consumption enough to pass the fuel consumption law..
so that was the fuel saver oil... lol
I think I will change to a different brand of oil...
Castrol don't give You any info on them especially ZDDP..
and have definately changed their oil specs recently...
GTX 2 has gone... Now there are Two GTX...
and two or more magnatecs...??
h - November 25th, 2011 at 10:21 PM
Originally
posted by vlad01
posted by h
it shoulda stuck on
cnfabo - November 25th, 2011 at 11:02 PM
Originally
posted by Craig Torrens
don't see why you would need a external oil cooler when you only race hillclimbs....circuit stuff yes.....
matberry - November 25th, 2011 at 11:26 PM
Col's 2332 is 140+ rwhp and has no ext cooler, just stock doghouse and 9.7:1 CR, ceramic coatings definately help though. It's all in the engine
build. My new car has an old 1915 and it runs heaps hotter but makes less power than the 2332. During an engine optimisation, it's often possible to
make more power with less engine temperature, comes down to the engine build details.
vlad01 - November 26th, 2011 at 11:14 AM
Joe Gibbs oil is ace!
A Raby developed version should be available at Joe Gibbs distributors. That version is called "Joe Gibbs Driven DT50" oil specially for the VW and
Porsche AC engine.
Years or R & D went into this oil and its a carry on from the Snake oil that Raby developed with Joe Gibbs oil chemists at hand.
can't see it on their site but I am sure if you request it they can get some in.
h - November 26th, 2011 at 01:35 PM
castrol = crisko
