Flywheel Stuck!! Help!!
beachbuggy61 - November 28th, 2011 at 07:44 AM
Hi all,
I've bought a new Scat 8 dowel flywheel and have put it on to check end float etc (planning to take it on and off a few times before putting seals in place and so on) and it's stuck! Normally I find a couple of levers and a bit of a wiggle and they come on and off pretty easily, but this one has stuck fast on the first go.
Any ideas on the best way to get it off? A big gear puller perhaps?
Any input appreciated.....
Thanks, Marc.
donn - November 28th, 2011 at 07:54 AM
FBH ?
beachbuggy61 - November 28th, 2011 at 08:00 AM
FBH? You've lost me.....
donn - November 28th, 2011 at 08:04 AM
I've got one. looks like a realy big hammer, so mine's a RBH :D
Sorry, not much help, but I'm filling in time. :rolleyes:
matberry - November 28th, 2011 at 08:14 AM
Give me a call and I'll talk you through it.....or but a Gene Berg Book of Instruction.....it's detailed it there!
beachbuggy61 - November 28th, 2011 at 08:21 AM
Haha, right, got it now thanks Don! I'm not keen on hitting it though......
Matt, thanks, I'll give you a call...
vlad01 - November 28th, 2011 at 09:07 AM
don't hit it! it will damage the seating area for sure even if you can't see damage there will be some.
yeah I am not sure how you would get it off without wiggling it or belting it?
Perhaps 2 opposing pry bars in sync while someone holds the flywheel to make sure it doesn't skew or knock the crank end on its way off? hmmm not sure?
68AutoBug - November 28th, 2011 at 03:15 PM
Originally posted by beachbuggy61
Hi all,
Thanks, Marc.
Hi Marc
don't they have threads to screw bolts into, to take them off
beachbuggy61 - November 29th, 2011 at 04:28 PM
Flywheel sucessfully removed!
Nothing that can't be achieved with a 20 tonne three arm hydraulic puller. Didn't even have to pull very hard in the end, just gentle application of Pascals principle and she came off smoothly.
Not an FBH in sight!
Thanks for all suggestions.
